Timer light switch for use with Led bulbs
6 Aug 2008
Lanarkshire
I've installed 5 downlighters outside my house in the soffit.
I've used LEDs bulbs (sylvania 2.5watt equal to 25w halogen)
I would really like to install a timer switch to programme when they come off and on.
Everyone I've researched says not suitable for low voltage lighting. Can anyone recommend a timer switch for use with leds?
Thanks in advance
If your lamps run from 230V, they are not low voltage lighting. If your lamps are run from a separate Driver power supply, put the time switch in the 230V supply to the Driver power supply.
[pedantic] If his lamps run on 230v AC, they are low voltage. If below 50v AC then they are extra low voltage[/pedantic] ;)
http://www.amazon.co.uk/Day-Electronic-Wall-Switch-T40-S-C/dp/B0018S13PO/ref=pd_sxp_grid_i_0_1.
Amazon said:
Replaces existing light switch ... Not suitable for fluorescent lamps
Which is because it has no neutral, and needs a trickle of current through the lamp to work.
It won't be suitable for LEDs either.
That is a good point, the ones that are designed to replace a light switch will probably be designed to trickle some current.
If you are wiring the lights in from scratch, providing a neutral at the time switch should not be a problem. If this can be done, then there are plenty of timers available. The trick is not to look for timers for "lighting". These are examples that would work if there is a neutral at the timer:
Screwfix product code: 96608
Farnell order code: 987037
