Hi All,
We are about to redecorate our bedroom and as part of the redecoration I want to move 2 plugs. They are both on a ring main and there is one either side of our bed. However they are not easily accessible so I want to move them both a distance of about 1-2ft. I can see that I have 2 options and both are equally valid but I wanted to get some professionals advice as to whether one way is more "acceptable".
Both sockets are sunken into the wall so I can either buy a new socket then chock block two lengths of cable to extend the ring. the old socket would be covered with a blanking plate to allow access to the joint.
The second option is to buy a new socket then using a chock block to run a single cable from the ring in the old socket to spur the new socket in the new location.
Our walls are made from insulated plasterboard cavities so I would propose to pull the cables through the cavity
Rich
Rich
