Toil Rad socket
25 Jan 2007
Hi, Iv got a toil radiator to plug into an existing socket in the wall.
Only thing is Im not sure how ot wire it in. When I pulled the cover off the socket in the wall it isn't clear where to put my three wires coming fomr the towel rad. Looks like theres three connections with two wires already connected to each. Isit just as case of fitting mine to each of these connections?
The socket has an on/off switch on the front and a hole in it for my wire to go through.
hope this makes sense, cheers
ah i belive its flex outlet spur switched or unswitched is unsure but i would go for non switched as your radiator has a switch on it, you got live red or brown, neutral black or blue, earth green and yellow, be careful and check the power is off if your wanting to DIY
first off it's not a socket it's a flex out spur...
secondly.. there should be 3 more terminals labeled as L (LOAD), N (LOAD), and E (LOAD)
these are the terminals that you should connect to..
to be honest though... if you can't figure that out you might be safer getting someone more qualified in to conect it.. a family friend maybe etc...
sounds like a flex outlet plate.
is there a spur somewhere controlling it?
it's a switched spur ( fused or unfused not certain.. )with flex outlet hole..
can you do us a photo of it.. good focus and light please..
