Toilet flush handle not working for a WC with a hidden tank
5 Jan 2012
Berkshire
Hello,
As the title suggests, I have a WC with a tank which is well hidden behind a wooden panel, with a marble slab on top. There is no opening available to lift the marble and gain access to the tank. It is locked pretty tightly.
The flush handle (which is accessible through a tight hole in the wooden panel) has been temperamental for some time but has now completely stopped working.
Can anyone suggest a suitable course of action? Is this a big job requiring an experienced plumber or can it be done as a DIY?
Many thanks in advance.
More likely be easier to remove the tongue n groove wood and go from there.
Rather than trying to remove the marble and break it.
The wood is easier/cheaper to fix.
You need to gain access somehow, the top should come off, it went on
The top is sealed tight. There is no access plate or anything.
So, what would be the best approach? Break off the wood and get the tank/flush fixed?
Thanks.
The marble top is the last piece to go on. Remove any silicone around the edge of the marble and it will lift up.
I've done many of these (and so has Seco)
Andy
I concur with the above. The top HAS to be the last piece fitted. It may be stuck down with a bead of silicone that will need cutting with a craft knife.
If you REALLY can't shift the top, running a craft knife down the joints between the T&G boards cutting through the tongue may loosen a board without too much damage. I had to do that to get to a leaky connector on a bottom fed fill valve in an almost identical installation.
