Toilet has lost its power when flushing? how to fix
12 Mar 2016
Hello all
My toilet has lost its power when flushing. I lifted the lid and pressed the blue button and wow it works like it use too, really powerful! however for some reason when I press the button ontop of the lid it does not appear to be reaching the button UNDER the lid for some reason anymore.
How can I fix it? is there a universal thing I can fit to replace the old one?
does it have two threaded plastic bolts on the underside of cistern lid ,they may just need adjusting and the lock nut tightening up.
Yes it does have two plastic stick looking things, looks like a lolipop stick. Didnt know they were bolts that could be tightened with a screw driver. I will have to have a closer look. Thanks.
take a pic and let's have a look. you don't use a screwdriver if its the type I think it is.
Yes I will take some pics of it. I was trying to find a youtube video on how to do what you mentioned, but couldnt find one. If you maybe could have a quick look to see if you can find a youtube video you probably would have more luck as I have no idea what type in to search.
that video shows many different types, if. yours is like the first one shown on there , its real easy to do. just turn the threaded bolts anti clockwise ,and they become longer , until they reach the flush valve .takes a bit of trial and error ,as you have to adjust it ,put lid back ,see if when you lightly press the button if it feels as though its touching underneath. take lid off ,adjust more ,try again ......and you have to do both threaded bolts ,independently of each other. as one controls the half flush ,the other the full flush. when the adjustment is correct ,the silver buttons on top should have no free play ,in other words as soon as you start to press you feel resistance. At that point you tighten the little nuts which lock the bolts in position.they are at the end of the threaded bolts ,where they meet the body.
https://ibb.co/e8wH0F
https://ibb.co/bHdVLF
Heres some pics. What I did was exactly what you said, those 2 plastic screws that are there, well I unscrewed them a little, maybe 4cm to make them a little longer and put the lid back down and presto, flushes powerful again!!!
Thanks so much for the advice!!! most appreciated!
