toilet inlet
27 Oct 2003
What connection do I need between the 15mm toilet inlet pipe and the plastic threaded tail of the ball valve? Is it just a (1/2") tap connector?
Also does a coupler exist that has a built in isolator valve - so basically 15mm compression > isolater > (whatever needed to fit plastic thread)?
James
thanks. the one to be replaced is so corroded it's beyond all recognition.
