toilet on floorboards or laminate?
13 Feb 2010
Glasgow
My downstairs wc currently has the toilet removed and the laminate flooring has yet to be laid.
Should the toilet be fixed onto the floorboards and the laminate laid around or should the toilet be fixed on top of the laminate flooring once laid?
2 arguments here
you should not impede free movement off the laminate allowing 12mm expansion all round
now the reality if you don't fully seal any cut edges around the toilet your risk ----well the smell off stale urine is enough -- well you know
i always go for under the pan as you have to fill the expansion gap with silicone to stop any dribbles collecting if you cut round :shock:
in general bathrooms are small so undersized/non existent expansion gaps/pinched laminate is ok as the other edge will accommodate the expansion
Nooooo don't put laminate flooring in a room with water in it, even the bathroom-rated stuff will swell over time as it inevitably gets wet, it's all basically a bit cr@p. Get yourself some Karndean, looks like laminate but is actually genuinely waterproof with a 12, 15 or 20 year warranty depending on which range you pick. Much better stuff.
Oh yeah, and lay it under the pan
