Toilet problem after water supply turned off
14 Feb 2014
Derbyshire
Last night the water board turned off the water for several hours in the area I live and replaced an underground water main due to it leaking. Since then my toilet has been making a very loud banging noise just as the cistern stops filling up. I can only describe this as being like a firework going off in the toilet tank. Furthermore the water in the tank is filthy once it has filled up a dirty off white colour that does seem to clear after letting it sit for a few mins.
The problem is clearly an issue with the toilet as running other taps no problem can be noticed and the water seems normal looking. I am wondering if somehow some grit or dirt is in part of the toilet pipework following the work done in the street. I actually live on the road the work was done on.
I thought it could be a water pressure or water hammer issue after doing some google searches today but seems a strange coincidence its happened after all the work was done. Anyone got any ideas how to try and resolve this issue or what to look for, where would grit or dirt have gone into the pipe work.
Red inserts in Part2 or 3 float valves are for low pressure ( gravity) supplies!
Quite often when mains supplies are disrupted, particles of grit etc can find their way into the house and cause the symptoms you describe.
Failing that, you may have a Torbeck valve that has come to the end of it's (now) short life.
+1
Red is for tank fed and white is for high pressure.
While you are working on it, turn the water back on for a minute or so, and let the water gush out from the open pipe to wash away grit, rust or scale that (sounds like) is in the pipe.
