- Joined
- 1 Oct 2006
- Messages
- 148
- Reaction score
- 1
- Country
I am trying to fit a new toilet into a bathroom, but I can't connect the soil pipe. Here's the problem:
The soil pipe is raised 6cm from the floor. The base of the ceramic connector on the toilet is 15cm high- so the connection needs to drop 9cm. The toilet is designed to fit flush (no pun intended) against the wall, which means the ceramic soil pipe connector on the toilet ends only 9cm from where the wall will be. (Not sure if it's relevant, but the ceramic tube is 7cm long).
I have tried a concertina type flexible connection, but it is too long, although it makes the drop easily enough, so the toilet will not fit against the wall.
oh, and the wall is tiled, so moving the pipe in the wall is a no go.
So, anyone know how I can drop 9cm at a 45 degree angle?
Many thanks in anticipation.
Andy
Andy
