Toilet seat replacement on back to the wall toilet
7 Feb 2012
Somerset
Couple of images attached. Is it possible to replace this toilet seat without un-plumbing the toilet to gain access to the underneath of the bowl.
andytw
full
full
Start by pressing /pulling anything that looks like a button, if that fails try removing the screws and as a last resort there is always the hacksaw.
Undo and remove the two screws ,one in each of the hinge bases. that should enable you to pull up ,and off ,the seat. That will reveal the anchorages ,which you can then establish if they can be removed from above . post a pic of them if need be.
And when you do get a suitable replacement seat, try and silicone those massive gaps at the side of the pan :eek:
We’ve got a similar setup on our upstairs toilet. Remove the two screws and the seat should pull off, leaving two pins/studs. Holding those studs on are a couple of butterfly/toggle screws. Undo the screw and the posts and screws can be removed. The butterfly screws are something like this.
