toilet waste pipe fall
11 Feb 2011
Manchester
I'm having a downstairs toilet installed. Its 4 meters from the toilet to the soil stack. what is the minimum fall need from the toilet waste pipe into the soil stack.
Thank you in anticipation
Straight 4m pipe from behind the wc - ( bent pan connector) 50mm higher @ WC than T into soil stack ;) That really is the min. with these low water flushes. should be steeper but that`s a real world scenario using one length of pipe
Minimum required under Building Regs is 18mm/metre or total 72mm for a 4m length pipe; personally I try not to go less than 25mm/metre.
I assume you are aware that installing a new W/C is controlled building work, subject to several Building Regs. should be notified & inspected (fee involved). If is to be inspected, the BI won’t pass it if the fall is less than the minimum.
