- Joined
- 30 Jul 2008
- Messages
- 3
- Reaction score
- 0
- Country
Hello everyone,
I have to replace my toilet. The waste pipe is in the floor, not through the wall and I'm told this may be a problem when buying a new close coupled toilet.
The distance from the wall to the edge of the waste is 110mm.
I have seen a toilet and when fixed to the wall, the distance from the wall to the edge of the waste (where the pan connector would go) is 145mm. I am told that a 'flexi-connector will be the most suitable type and that because a lot of the end of the connector fits over the part on the toilet, the flexibility will be more than enough. All sounds fine, but it was the guy in the shop who gave me this advice and just wanted to get a 2nd opinion, just in case I went ahead and bought the toilet only to find it wont connect to the waste properly.
Sorry to waffle on, just wanted to make sure I gave all the relevant info.
In summary:
Distance from the wall to the edge of the waste pipe (which is in the floor is 110mm.
Distance from the wall to part where pan connector fits is 145mm.
Basically, will this 'flexi connector' do the job or shall I look for a different toilet which has a bigger gap from the wall to the connector on the toilet?
Thanks in advance.
In summary:
Thanks in advance.
