Toilet with an outward outlet/s trap
20 Feb 2011
London
The toilets that the oputlet goes down instead of horziontal into the stack - how do they work? do they join the stack under the floor or does the pipe then run horizontal under the floor and into the stack?
they are most often used where the soil pipe on a downstairs WC goes straight down through a concrete floor.
They are very tiresome to replace as it is difficult to get a modern one that exactly fits the distance from back wall to soil pipe, and digging up a concrete floor is a terrible job.
mine is upsatirds tho!
I need to change it and am thinking of maybe getting a low levl one so I can use existing pan connector as don't want to disturb concrete!
sorry I haven't got a camera to take pics to load up.
basically the pan connector goes into a concrete raised ring and it must go through floor. Not sure I want to disturb the concrete ...
concrete raised ring - not asbestos cement pipe is it :? Argh evacuate the street :wink: you should get some sort of pan connector to fit but the close coupled WC cistern might need to be battened off the wall a tad
