toilets
4 Jun 2009
Southampton
hi i have a problem with my 2x toilets just lately after flushing either toilet, the water to the cistern just trickles in as where before it flowed in until valve was at its cut off point,the pressure to all other appliances ie taps is fine n e 1 have n e ideas thanks
Are they really fed from the mains or from loft tanks?
Dirt may have blocked the small orifice in the float valve?
Tony
It's simple and cheaper to replace the washers. Especially if they are plastic ballvalves. This answer doesn't apply if you have Torbeck equilibrium valves.
