I want to top-fit 3 x roller blinds in the recess of a 3-pane sliding door. Each blind will be 1.8m wide, 2.1m drop. Naturally we have a massive great steel spanning the gap above the doors with dot-and-dab plasterboard stuck to it. I've been put off drilling up into steel lintels by a semi-botched previous attempt in another room. It just didn't feel right and I have nowhere to practice.
I'm going to get motorised blinds, so my theory is that the downward force on the blinds will only ever be the weight of the blind itself (and not the tugging force of a human hand on the blind / pull-cord). On that basis I only need a fixing strong enough to hold the blind's weight, which would be about 5kg tops. Therefore I'm thinking 3 x GripIT fixings per blind (one in each of 3 x brackets) @12Kg each under tension force (https://www.gripitfixings.com.au/pages/gripit-table), gives me masses of headroom.
Can any of you bright folk see a flaw in my plan? E.g. would the dot-and-dab adhesive be strong enough? Are GripIT rubbish?
