Cistern stopped filling today, hubby broke the valve trying to fix it. Duly went off to shop and picked up a Torbeck bottom entry adjustable float valve and installed it as per directions. Except that when the cistern fills now, it leaks like crazy from the height adjusting nut
(bottom blue nut on this pic:
When you move the ballcock up, the flow at the valve head stops fine but water continues to leak from around the blue nut and adjustable height columns -- it says "hand tight" on the instructions which I did, also there's no mention of a washer for it?
Can't figure out why this is happening. Have fitted the high pressure flow reducer but no help. I think I'll just go get a Fluidmaster instead but wanted to know if I've done something wrong setting this Torbeck up, or if it's just a dud.
