i need to renew a bottom fed torbeck valve.
the measure to top of water level is 8and a half inches.
could someone please tell me if this equates to the sixe of the torbeck valve.
cheers for reply.
i agree.bought a 9and half inch one which was too small.
couldn't see a larger one at b and q or in screwfix book.
found a replacement washer and it seems to have done the trick.
was only going to replace the gubbings that come off with the nut, however the new one didnt have a pin to locate the washer, so bought a replacement washer.
thanks again.
