ok in my defense this is my first house so please help
my girlfriend turned our livingroom into a pond the other week and next door came to assist as i was away visiting family. now we have an issue with very low pressure on the hot water throughout the house. this results in all the taps stuttering and splattering but more importantly the bath tap comes on fine and then after a few seconds dies out even on full open
i am unable to locate where the stop vave is for this. if anyone is in the aberdeen area these are the new houses in ashwood. the nieghbor is away at the moment and i need to get this sorted as im feeling pretty grubby
i have located the following
under the sink in the kitchen, there is a set op red and blue stop taps i presume are for the washing machine next to them also a single tap which does not seem to affect anything?
in the bathroom there is a cupboard with a "hercal" coil indirect heater
there are 2 pipes that run off this that are hot water (by touch) and neither of these have a release valve of any sort. they do however have a small grey box marked potterton model no msv322 and a larger one i cant get to.
there are also 2 pipes coming from the loft that are cold to the touch and have release valves, neither of which affect the hot water
in the loft there are 2 tanks of water. 1 is cold as can get the lid off the other i am not sure about. there are 3 taps up here which will not turn with a reasonable amount of force by more than a millimimetre each way. im a little frightened to force them to turn given that ive already made an insurance claim
is anyone able to point me in the likely location of the hot water tap? i know my description is likely very rubbish but im just a pc engineer all this diy stuff flies over my head
