Hi, i am going to replace the radiator in my bathroom with a towel rail. I bought the towel rail today, and after opening the box in turns out that the towel rail is not supplied with any radiator valves and the instructions do not say anything about valves.
There are four connectons that need to be made to the towel rail two at the top and two at the bottom. I assume the two connections at the bottom are the chrome radiator valves, and that one of the connectons at the top is a blank connection, and the other connection at the top is for a bleed valve. Could you tell me if this right? and exactly what types of valves altogether i need?
Also should the altered pipework be done in chrome pipe? or should the altered pipework be run in copper and have a chrome sleeveng put over the top of the copper pipe?
Thanks in advace
Thanks in advace
