tower shower flexis
4 Mar 2013
Bradford
Hey have fit a tower shower thats connected by flexis and has two clips holding it to the wall however because you need to leave alot of slack on the flexis to be able to lift the shower on and off the clips. I am concerned the flexis will be bent too tightly when the showers pushed down on the clips. Any one had a similar problem? Its a thin tower shower do not much room for the flexis to bend.
The only solution is to leave the pipework size to minimum possible, that will allow you to remove the shower, unless you can gain access to the unit from behind.
