Trace Heating Wire On HEP2O Plastice Potable Water Pipe?
Discussion in 'Plumbing and Central Heating' started by smarty, 24 Dec 2010.
  1. smarty
    smarty
    20 Mar 2006
    48
    Thanks Received:
    Country:
    I recently bought some trace heating wire/tape off ebay as I have had numerous problems with pipes freezing in my garage, the last one caused a full-on leak. The pipework is a mixture of copper and I think it is HEP2O or similar that Focus sell. The trace heating wire is this:
    http://cgi.ebay.co.uk/Trace-Heating..._Hearing_Cooling_Air&var=&hash=item895f2ba185
    I never thought if it is ok for use on the plastic potable water pipes. I could change it all to copper but would rather not unless it is essential. Or should I just wrap the plastic sections with aluminium tape before attaching the heating wire? Thanks for any help.
  2. Sponsored Links
  3. oilhead
    oilhead
    29 Nov 2009
    2,182
    Thanks Received:
    524
    Shropshire
    Country:
    Should be O.K for plastic pipe. Unfortuneately the watts per mt is not specified on the web site, but it is stated as self limiting. Ask the supplier what temp it limits to. If in doubt, plug it in away from the pipe, and see how hot it gets. Bearing in mind your plastic pipe is designed to handle hot water in heating or domestic supply temperatures, you shouldn't have a problem.
  4. studips
    studips
    12 Jan 2009
    421
    Thanks Received:
    50
    London
    Country:
    i've got trace heating tape on some copper in an outbuilding, it's just a trace of warmth - mine is only 10 watts per metre under some armaflex.
  5. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
