It's interesting you should say this, since the usual discussion we see here is about the alleged (which I don't think is necessarily true) reduction in life of a halogen bulb/lamp if it is run at under-voltage, and therefore with a capsule temperature less than the very high one needed to optimise the halogen cycle.The SMPTs usually quote an effective output of 11.8v. I remember reading years ago (10?) about running transformers at full load but I must admit I've not done any tests. Halogens do run very hot however so it makes sense that they are voltage sensitive.
Kind Regards, John
