Transition from Copper to Barrier pipe 15/15 & 22/22 (mm
6 Sep 2007
Lancashire
Is there a special thingumi connector for this ?
Or will just ya everyday standard push on thro connector do ?
Link to a pickkie would be good if no  8)
Whoa ........ Do I just use a Compression fitting & whack in a insert & things ?
pushfit or Compression with insert.
metal inserts are better with compression fittings.
Use a standard speedfit connector, insert in the plastic pipe, no insert needed in the copper pipe.
Just bear in mind earth continuity.
