Is there a maximum 15 mm pipe length from the 22 mm ring?
15mm tube will carry a 6kw load @ 10c dt. (0.14 x 4.2 x 10c = 5.8 kW)
But the OP is only fitting 2.6kw worth of radiators. Half of what you suggest is OK.
So 15mm will carry the OP's load fine and dandy then?
Or is it actually oversized if 20dt is used?
Mebbe some cheap 10mm microbore would do at 20 dt?
  • Thanks
Reactions: DP
Bloody he'll challenging Steely on equations,this will be funny
No equations required.
Steelmatron couldn't answer the OPs question.
He says 15mm is good for nearly 12 kilowatts but can't give an answer as to whether it will supply the OP's 2.6kw.
