travertine tiles on floorboards
Status
Not open for further replies.
4 Nov 2006
hello could someone please tell me the best addisive to lay stone travertine tiles on floorboards in a bathroom any advice would be much appreciated , thank you
Don't lay them straight onto the boards either softwood or chipboard.
Overlay with 12mm Aquapanel or 15mm Ply screwed art 200 centers
If this gives too high a floor height then take up all the existing boards and replace with 25mm WPB ply and additional noggins under any joints, this is what I usually do.
Use a flexible white powdered adhesive such as BAL rapidset and a flexible grout like BAL Superflex wide joint grout.
Jason.
Many flexible adhesives can be used over boards when screwed down according to the instructions (especially in a small area like a bathroom). There is no difference from the point of view of the tile between a board or ply.
It wouldn't be on the back of the pack if you couldn't do it. I dare say they have tested it first eh?
joe
your attempts of helping are silly here ....
NEVER TILE ON FLOORBOARDS !!.........
Moz said:
joe
If it says on the back of the pack that you can - then rest assured that you can.
Tell me the difference between ply that is well screwed down and boards that are well screwed down.
Moz said:
joe
no more silly here than every where else on the forum!
So the instructions on the back of the pack are wrong are they?
Maybe YOU can tell us the difference between boards that are screwed down and ply that is screwed down? (he won't)
joe
you have No idea what you are on about here ...
you are just trolling go play elsewhere ........thanks
Moz said:
joe
Floorboards will move/expansion an tiles will fail ....
now go troll elsewhere ....
Not when screwed down as directed on the pack. Just follow the instructions.
The REAL problem is if the joists are springy - nothing to do with the boards at all.
Have you ever done any tiling? Guess not eh?
Status
