    Dismiss Notice
Treatment of mock tudor beams and gable timber in victorian house
Discussion in 'Decorating and Painting' started by sbsuresh, 22 Apr 2020.
  1. sbsuresh
    sbsuresh
    22 Apr 2020
    2
    Thanks Received:
    Country:
    Hi
    I am looking for some advice regarding how to go about treating this timber and making it look new and last longer.
    I am looking at getting some oil/wax and then followed by veneer to finish off? ?
    any advice would be gratefully received
    thanks
  2. Sponsored Links
  3. JohnD
    JohnD
    15 Nov 2005
    63,821
    Thanks Received:
    3,375
    Gosport
    Country:
    Cook Islands
    Is it indoors?
  4. sbsuresh
    sbsuresh
    22 Apr 2020
    2
    Thanks Received:
    Country:
    hi John
    the Timber is outdoors no rotting or insects ...but general wear and weather damage
  5. Johnny Allround
    Johnny Allround
    27 Mar 2020
    459
    Thanks Received:
    88
    Country:
    Hi sbsuresh, you might want to post a picture of the area you would like advice on. There are a lot of knowledgeable trades people and diyers that could point you in the right direction. Hope this helps.
  6. Johnny Allround
    Johnny Allround
    27 Mar 2020
    459
    Thanks Received:
    88
    Country:
    I would personally look at using Sikkens basecoat and then the top coat. If you’re after a long lasting quality finish look no further. It’s a bit pricey but you get what you pay for.
  7. opps
    opps
    16 Jun 2006
    4,144
    Thanks Received:
    622
    London
    Country:
    Veneer? Or do you mean varnish?
    Ordinarily mock Tudor timers are supposed to look aged, however, if the timber is fairly bad you can fill and splice any rotten timer with epoxy resin filler (search for Timbabuild or RepairCare). Epoxy resin fillers are pretty expensive though and you will been to buy the branded skeleton guns to dispense the filler. Timbabuild's gun and fillers are significantly cheaper than Repaircare's (but still expensive). If you do fill any timber you will need to consider using a finish that will mask the colour of the filler.
  8. Sponsored Links
Loading...
Share This Page
