- Joined
- 28 May 2025
- Messages
- 2
- Reaction score
- 0
- Country
Morning folks, thanks for having me.
I would like to move a ground floor toilet across the room to separate it off and create a walkthrough.
The room is about 3m x 3m, concrete (and tiled) floor. The toilet is located at 3 o'clock against an outside wall with the pan connector disappearing vertically into the tiled floor. I want to move the toilet to the corner to the left of 12 0’clock.
This floor is about 40cm above the outside ground level, and the soil pipe about 40cm (to top of horizontal pipe) below ground (i dug a hole to locate it).
For the soil pipe from the desired new location going out and around the outside of the building may just about be possible fall wise but it would seem to me be a lot simpler for me to trench across the bathroom floor deep enough to drop in a straight 2.5m length of 110 with a 1 up and 1 down 92.5 bend on each end and joining to the existing vertical soil below ground.
Is that feasible? sensible? Would there be possible issues going through a dpm? (assuming there is one there).
many thanks in advance.
