Trent wc
24 Aug 2006
Yorkshire
I have just bought a trent wc which does not have a donut seal but a flat thin rubber gasket that says it needs to be glued onto the pan and the cistern. If this is the case and still leaks, how can it be repaired. I have tried doing the seal without glue, but it leaks profusely at the back and looking under the cistern, you can see that the seal is not connecting to the cistern or pan. What should I do? I have checked that the pan and cistern are level.
its not a donut...its flat and is thesize of the cistern, with a triangular shape missing in the middle where the water goes into the pan...a donut is the wrong design and would not fit
