Triton Ivory 3 Shower problem
24 Oct 2012
Glasgow
I have an odd problem with an Ivory 3 shower unit that I installed a few years back.
For some reason the on/off dial has started to rotate freely without operating the shower. The unit hasn't been damaged and hasn't been opened since installation.
I took of the face plate and there were no signs of damage to either the on/off dial or the switch below and no loose parts fell out. When I manually rotated the power selector switch without the face plate in place the unit functioned normally. The issue therefore seems to be that the face plate dial has stopped engaging with the power selector swithch below. I have no idea why.
I spoke to Triton and they weren't able to help as without any signs of damage or inspecting the unit they cannot advise on a means of repair. I don't want to buy another face plate if it may not solve the problem and it canot be returned once fitted.
Has anyone come across this issue before? If so how was it sorted out?
Can anyone suggest a means of sorting this? I have considered trying to shape a short piece of wooden rod to fit into the hollows in the back of the face plate dial and the front of the power selector switch to create a connection between the two but hoped there may be an easier way.
Seen it once on this shower model.
Check the inside of the dial where it connects to the switch assembly has it cracked.
If they crack it opens up when turned instead of gripping the switch assembly.
Thanks for the rapid and helpful response Seco.
This makes sense - I will take a closer look at the dial.
Seco - you were spot on!
As you predicted the inside of the dial had a crack that was invisible when the face plate was removed from the shower, but opened up when the dial was turned allowing it to rotate freely.
Bit of wire tightened around the dial and it was as good as new.
Thanks again!
:D
