I am having a problem with my shower it has only been in 2 years and i have to have the temp dial at 8 to get any heat and then there is no pressure and have to run around to get wet, whats the problem?
It is a hard water area but i have clean the shower head and hose and this has not helped it has been like this for about 6 months now, i think it is something to do with the actual shower body
You've either got a faulty element or the bottom tco has failed.
Check the elements for resistance with a multi meter.
Check the bottom tco for continuity Also loose or burnt/damaged connections.
If all those prove ok then look at the micro switches but thats a last option they rarely fail on these.
