Newbie on here so be gentle!
Fitted 9.5kw Jade II about 6 months ago. tested all fine. finally finished the bathroom just before christmas and started using it. all well for 2 months and now problems..
Flow rate reduced and also temp reduced. Ambient water pressure fine but not measured, low pressure indicator on shower not on (it was on once or twice pre use when testing).
There are 3 main heat settings - on max heat (considered std use setting) and approx 6 on the temp (out of a range of 10, not 11!) the water was a good hot, with reasonable flow rate. Now its luke warm and a average flow. Turn it up to 10, flow drops to a miserable flow and temp is about 15% cooler than normal No6.
What have i checked?
Inlet filter (2" long gauze tube fitted on back of bottom outlet plug) all clean (did have a couple of tiny copper bits in it).
Shower head - currently descaling in the kitchen although barely used.
I tried the head off my other mixer shower and its flow rate was a bit poor too - so that removes the possibility of the head being scaled up.
Case cover off, checked all terminations - all tight.
Naturally the warranty ran out on new years day! FFS!!!
Run out of ideas.... help please??
