I am trying to drain my hot water system so I can fix a couple of leaks and replace some radiator valves.
The only drain valve is right next to the boiler (lowest point as is in basement) so I turned off the water to the header tank, opened the valve and loosened the radiator bleed valves upstairs. Water came out but even after 24 hours the downstairs radiators are not drained. Why could that be?
I noticed the drain valve is in the flow pipe out of the boiler, not the return back to it. Is that normal and could it be the problem?
