Hi Guys
So I am working on renovating my stair case. I am quite a competent diyer and have fitted bathrooms, plastered, done plumbing etc. However, I have never dealt with a staircase before so I would appreciate some guidance.
Right, so the objective of this project is to replace the newel posts, fit in a new baserail and handrail with spindles. The current setup consists of three newel posts, one from the bottom of the stairs to the top and then one on the wall which makes a balcony.
I have removed the current handrail and chipboard that slotted in between the base and the hand rails.
My first problem is the newel post. Instead of being seperate from the steps, it has been cut out to fit into the lowest step. See image below:
My question is, should I just yank it out ? Or shall I just cut it ? Also, I guess if I want to fit the new newel post I will have to cut it out in a similar fashion ? Is there any other way I can approach this ?
My second problem is the fact that the baserail is too wide. Below is the img for the existing rail and alongside it on the left is a plank of timber that is the same thickness/width as the new baserail. See:
Any advice on how to overcome these issues would be much appreciated.
Regards
Regards
