Troubleshooting Worcester Greenstar 32CDi No Hot Water
Discussion in 'Plumbing and Central Heating' started by abusimbel, 15 Jul 2019.
  1. abusimbel
    abusimbel
    1 Mar 2008
    31
    Thanks Received:
    London
    Country:
    Hello All!
    Thanks for anyone's thoughts on this!
    I thought I would quickly put my boiler trouble on this wonderful forum to see if anyone wants to offer there thoughts.
    Our Worcester Greenstar 32CDi Compact Boiler has no hot water.
    However, the pre-heat water function DOES heat the water. This means we get about 20 seconds of hot.
    The boiler DOES NOT fire when drawing hot water.
    The Blue light is OFF.
    The Central Heating System DOES work
    I have run three of the boiler 'tests' and these seem to be working: Igniter Test, Fan Test, Pump Test.
    Diverter Valve? Flow sensor/regulator?
    Thanks thanks thanks for any thoughts!
  2. mrStat
    mrStat
    11 Mar 2017
    174
    Thanks Received:
    63
    Hertfordshire
    Country:
    Sorry, that’s a case off job. Give your local RGI a call, shouldn’t be too difficult for them to resolve but not likely to fix itself.
    • Thanks Thanks x 1
  3. Sponsored Links
  4. abusimbel
    abusimbel
    1 Mar 2008
    31
    Thanks Received:
    London
    Country:
    Thanks mrStat! I have made the call...hopefully they confirm availability...
  5. picasso
    picasso
    8 Apr 2008
    10,641
    Thanks Received:
    2,673
    Essex
    Country:
    Probably flow sensor and your boiler has a drop down service panel so no need to take the cover off.
  6. Sponsored Links
  7. abusimbel
    abusimbel
    1 Mar 2008
    31
    Thanks Received:
    London
    Country:
    Well, the heating engineer found the problem! Wire had been chewed by...something...
    He replaced the wires and the hot water is back on. Now we need to figure out how a...something...(probably a mouse?) got into the boiler! The house is very sealed. New windows and doors. The only way in would be through the boiler flue via the bamboo planter (now moved).
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
