Troublesome PIR sensor on outside light
10 Aug 2004
I have outdoor lights which work fine, but need to be manually turned on and off, so I added a PIR sensor from screwfix. I followed all the wiring instructions, and turned the light back on, and flicked the on switch. The lights come on, but do not turn off.
In the instructions, it says that the unit will go through a one to two minute testing phase before turning off automatically.
I am clearly doing something wrong, but I am asking if this error sounds familiar, and if anyone could suggest something to test and see if that works!
(I took the first PIR back, thinking it was faulty!)
That is quite confusing. However...
Have you supplied a permanent live and switched live to the pir?
