I have just fitted a thermostatic shower tower in my en-suite. I already have a shower in my main bathroom which is run through a gravity fed pump (both hot & cold). To connect the new shower, i just isolated existing hot & cold feed at pump and tee'd into the speedfit pipe. The problem i have is that sometimes the new shower will not work! It can be turned on but the pump doesn't operate. This morning, it wouldn't work and the flow control was left in the on position. The main bathroom shower was used and when switched off, the pump continued to operate. On inspection, i found the new shower had decided to switch on! What could be causing this erratic operation, airlock??
Thanks,
Gary.
Thanks,
Gary.
