Trowel for min 6mm bed attching Marmox
24 Aug 2004
Devon
I am about to start fixing marmox boards to thermalite blocks. I will prime the walls first with Mapei primer as they are quite absorbent.
The marmox instructions say to lay a minimum 6mm bed of SPF adhesive using a notched trowel.
Apologies if this sounds stupid, but i've not done this before :oops:, what size trowel would the pros use to achieve this? Does a 6mm notch trowel leave a 6mm bed, a 10mm notch leabe a 10 mm bed etc?
If you read the instructions it says to apply a 6mm coat then comb out with AN 8x8 NOTCH TROWEL
Jason
Jason
Not in the ones they gave me it didn't... The booklet said "Using a notched trowel, apply a bed of flexible tile adhesive (minimum of 6mm) to the wall. That's it.
But thanks for the advice, I appreciate it.
Edit, Just seen the instructions on their web site, should have looked there as well. :oops: They could have duplicated them in the leaflet they give to the tile shop.. :rolleyes:
