trowel size for 60 x 60 ceramic floor tile?
7 Jun 2011
Hello everyone
Can anyone suggest the correct trowel size for a 60 x 60 ceramic floor tile? I had thought a 10mm u notched trowel would be suitable but would appreciate some guidance from you.
Cheers in advance
Simon
Depends on the tile and the substrate.
Ultimately you check and use whatever gives the correct coverage.
OP,
Your 10mm u-notch trowel should be fine - are you intending to use tile levelling spacers?
