TRV Caps broken..pls help
1 Sep 2009
Middlesex
Hello,
I am pretty new to DIY as just moved into my own place. I am stuck with something and hope all you experienced hands can give my some advice. The radiators in my house have (or had Temperature regulates valves..lol). But all the tops (I mean the plastic bit on the top which rotates to regulate the temperature) are broken. The metal valve is there but the tops are gone. All that is left is a small round pin kinda thing left on the top of the valve.
Is it possible to replace just the plastic tops (so i could try doing it myself) or do i have to replace the whole valve?? (which i dont think i can do myself as theres a lot of other things i will have to do which i dont know i.e. draining the rad n all that business). If the plastic tops can be replaced, where can i buy them (e.g. B&Q, Homebase, etc). And are the tops universal or of specific type (i have one of the broken tops, its from a company called Terrier)
I have uploaded photos of the broken cap and the valve here. pls have a look.
http://www.diynot.com/network/SIDD/albums/3607
Thanks for your help in advance. View media item 14148 View media item 14149
Hi there,
Terrier is a product name of Pegler. Look them up on t'internet and they should be able to provide you with just the replacement heads.
[/url]http://www.pegleryorkshire.co.uk/newsarticle.aspx?NewsArticleID=233&CategoryID=16 Rico
Hi there,
Thanks for the info...Is it possible to install normal caps onto these valves (as I dont necessarily require the TRV caps) or for doing so I will have to change the whole valve..??
SIDD,
No these valves will only take trv heads.
Under Building regs your supposed to trvs anyway.
So changing to normal valves in a no-no
Rico
if you want to use them as normal wheelhead valves get some decorators caps
or leave them as they are if the head aint on the valve (should) be open
Thanks a lot everybody...Will do the needful...going to the shop now...
cheers :)
