if all TRV's are turned off on all rads in a house, will this automatically turn off the central heating? or will the central heating only turn off when the programmer /room stat tells it to do so?
i thought so. i don't knw about boilers but i know that a bypass circuit and automatic bypass valve can be fitted to allow the water to circulate if all trv's are shut down or for if you have a pump overrun. i know a lot of boilers nowadays have an integral bypass built in though.
... i know that a bypass circuit and automatic bypass valve can be fitted to allow the water to circulate if all trv's are shut down or for if you have a pump overrun.
