W
Woodendhead
Just been reading the Part P and wondered I am okay to replace a cable that is damaged, but what if I discover a cable that is obviously under-rated? I am guessing I am not allowed to do the work unless I turn the power off and damage it first
or it started to melt. But then I would have to replace it with the same under-rated cable. Thus to do it right I would have to notify. Would I get way with a notification that stated Replaced 1mm cable for a 2.5mm cable on the first floor ring main following the same route.
This might sound like that would not happen but I have had to have replaced the supply to the detached garage as it was a 2.5 mm unfused spur supplying 3 double sockets and the lights for a second CU and armored cable fused from the main CU (no idea what size as I dug the trench that is all before I get jumped on)
I am also very supprised to see I can replace my electric shower surely that is a mistake? I can't think of a place where it is more vitial to be 100% things are done just right.
