All,
I was trying to put back an old TS 350 for taking bits and pieces from several saw I had on the shed parked through the year and mostly with no spark.
I removed a coil from one case which seems to be showing 5.9K om and put into a semi complete case with cylinder etc etc. fitted a flywheel and there is no spark.
What should I check? The flywheel and coil should be matching as there only one type that fit for that coil. the other one won`t fit in.
I know it`s a long call but if anyone have any idea, otherwise I may have to bin everything and give up
