Tub or cement adhesive?
Softus said:
In case it's of any interest, I use a pre-mixed Feb product called Wetmix.
The shed stuff is garbage, but I've tried the Nicholls and Clarke equivalent, which is good, but I came back to Wetmix. I've used hundreds (since I only tile part-time) of litres of it, and it's bleeding wonderful. Not cheap, but so what.
Never heard of weetabix pre-mix, is it when you mix your breakkie up with worm milk!!! No, seriously, I've never heard of the stuff. I use Nicobond ( but their flexi powder gear is very takky) Howtex , but mainly Ardex,,,, blooming expensive.............
Where do you buy that gear from???
You can read about it here.
BTW, I believe that worms don't produce milk.
A curious question - I buy it from my local stockist.
You local stockist is probably not the same as mine - it all depends where you live and work.
My apologies to simonh1024 :)
I thought you an gcol were the same ......taking the p*ss here at my expense the other day ...
btw you can use BAL TILE & GROUT FOR WALLS tub mix which is good
No problems Moz.......................... :o
Cheers mate, I'll look out for the stuff.......................worms, where do I get off.................... :lol:
