Tumble dryer ventilation system condenstaion.
9 Sep 2013
Kent
Hi, I need to know exactly how tumble dryer ventilation works. I have just bought and installed a new PVC channel ventilation system and am having some difficulties getting to the root of my problems. The PVC channel runs up one face of an internal wall, between two roof joists and out of the fascia and soffits, the vent system is all push fit and fits snug between the insulation and plasterboard. The problem I face Is that the area in which I have chosen to run the pipe (shortest span from tumble to fascia) is very cold meaning that the warm air inside the vent pipe is condensating, turning into water and leaking back out of the joints within the vent system. Any advice on how to solve this? should I just run the vent in one section of flexi hose? should these vents even run through joists?
Thanks, Charlie.
Ideally, it should vent only a close distance from the tumble dryer. If it is located against an exterior wall, a hole should be cut into the wall to vent directly outside in the shortest possible distance.
The fact you are using an extended vent hose, in a cold environment, going vertically (I assume venting back down through the soffits), means that as you say the moist air is condensing before it gets outside.
I would also be concerned about the amount of moisture that will be condensing externally on the soffits and facia.
