Tundish leaking - how best to connect to waste?
4 Apr 2024
Hey folks, I have a water softener installed under the kitchen sink and as you can see, the brining pipe goes into the tundish and then directly into the waste pipe via one of those clip on cutter things.
Anyhow, I never really could get the tundish to sit properly on the waste adaptor, and, shamefully used plumbers mait - admittedly it's lasted about 4 years without leaking - but now it leaks... At the joint where that is , so I want to do it properly - but from memory I had a problem trying to get the bottom of the tundish to fit the clip on pipe - any advice or parts needed would be welcomed! Even if I have to take the whole thing out and replace the tundish with a different one etc.
Thanks in advance!
