I have a Vaillant Turbomax 242E (might be 282E, not sure) which is very difficult to get going when drawing hot water. First let me say that when there is a demand for central heating it seems to work perfectly. When turning on a hot tap though, nine times out of ten, the boiler will go through its start up routine, light and about half a second later will cut out. The diverter valve is almost new (the fully brass type) and has also had a new diapraghm as a precautionary measure. I can also see the arm on the right operating the microswitch and can also hear the click when the microswitch makes. That part all seems to be OK and works every time a hot tap is turned on, even if it's not very much. What seems a bit odd though is that the orange indicator light for the hot water will sometimes come on when a tap is opened and sometimes not. It is also sometimes very dim and seems to flicker, except when all is working well and it's bright. I thought that this light was controlled by the microswitch and therefore had to be either on or off! I have developed two ways to get the boiler to stay lit, one is to keep turning the hot tap on and off until it stays lit, the other is to leave the hot tap running and turn the boiler on and off using the green switch. However, even using these methods it will sometimes just cut out on its own. Another oddity is that if I fiddle about with everything it will sometimes work OK for a while. I called in the heating guy who installed it and he scratched his head for two hours, went through the fault finding charts and ended up giving me a new microswitch. The boiler worked for half an hour then started playing up again. Have to be fair to the guy though he didn't charge me a penny for the 2 hours but I think in the back of his mind he knew he hadn't solved the problem. Now I'm stumped and would welcome any suggestions as to what the problem could be.
Chris.
Chris.
