My daughter recently bought a flat with an 8 yr old Turbomax combi. The HW wasn't too bad in the summer, but as soon as the incoming cold water got colder, it is only luke warm. To have a bath, you need to run the hot tap really slowly, even then the bath isn't exactly steaming.
A relative lives in the same area, which has hard water, has a Worcester junior of the same output (24kw), but the hot water that comes out the tap is almost boiling.
The Turbomax's hw control is turned to max. Is there a problem, or are these boilers normally bad at heating water? The heating is fine.
