Any advice on this would be more than welcome
My Vaillant turbomax is not igniting after a water leak near it got it pretty wet
(no water got in to the circuit board housing)
It was working normally before this, following info might help:
Green power light on
CH light on
Fan light comes on
Ignition light comes on
It clearly sparks but then does not fire so the lockout light comes on
normal stuff is fine eg. pump is working, pressure is set at one bar
Taking all this in to consideration my 1st guess would be that something is now stopping the gas, as the gas supply is fine could it be the gas soleniod did not like getting wet???
Any thoughts gratefully received.
I have been a reasonably competent DIY plumber for 20yrs + and have successfully changed parts in the past (microswitchs, diaphrams, pressure relief valve, even a whole diverter valve and a DHW heat exchanger)
Cheers
Rob
CH light on
Fan light comes on
Cheers
Rob
