Turning a 3-way switch into motion sensor wall switch
5 Jul 2007
Turning 3 way light switch into 1 motion sensor switch
Hello, first time poster at DIY,
My house currently has two 3-way switch controlling a light at the downstairs entrance. I like to turn one of the 3-way switch located at the lower floor to a motion sensor wall switch.
I opened up the existing 3-way switch box and it has 3 terminals with 3 wires (black, red, white), how do I hook it up to my motion sensor switch which has 2 black wires and 1 green (ground wire)? My goal is to make the top floor switch either an independent switch, or "3-way" with the motion wall switch.
Any help is appreciated. Thanks.
Peter
i bet you cant.
this is a UK based forurm so terminology is different over here, BUT from what you have said it sounds like you can turn the same light on / off from more than one switch. over here that is called 2 way switching. to do this means you need a 2 way switch (it has 3 terminals, just like yours has)
a light that is only controled from one switch only has 2 terminals (just like your new switch has)
i would say that your new switch is 1 way, but you need 2 way
For safety reasons any motion sensor should only be wired as an over-ride ON function ( otherwise it could turn the lights OFF when someone was moving in the area )
You say the sensor only has two wires ? Can you provide a link to the manufacturer's installation instructions. Is it an inline type that does not need a neutral, only live in and switched live out
If so then it is possible that you could connect to sensor to obtain the overide function,
More detail is needed, the labels for the connections on the back of the switch or a photo would help
thats a good point, but the makes of pir / flood light combinations dont know that
See here:
http://www.electrical-online.com/extra-graphics/3wayswitch.htm
The best way I can see to do it is to fit motion sensors to both switch positions.
At the switch where the live feed comes into the common, take the live feed to one of the black wires on the sensor.
Connect a traveler to the same terminal, so you carry the live feed through to the other switch. Connect the OTHER traveler to the other black wire. This becomes the switch wire which links through to the other switch position.
The traveler you made a live feed in the first switch connects to one side of the motion sensor switch at the second switch position, and the other traveler (which is now a switch wire) connects to the other side of the motion sensor, along with the original switchwire to the light fitting.
This way, you have automatic operation of the light from both positions.
Just make sure the timing is set enough for you to get from A to B safely.
Does the sensor switch require a neutral connection, or just hot ones?
Here it is:
http://lighting.heath-zenith.com/products.cgi?type=4
Model number I have is SL-6105 (single pole)
Manual is: http://12.153.20.74/manuals/595-4881-09J.pdf
I like the idea of using the motion sensor as a over-ride, meaning it will be triggered on by motion but only comes off when I turn off the switch.
Can it be done? How?
Thanks.
Peter
I was able to take some pictures showing what I have:
Existing wall switch (lower floor):
http://members.shaw.ca/ppwlee/lowerswitch_back.JPG
http://members.shaw.ca/ppwlee/lowerswitch_side.JPG
http://members.shaw.ca/ppwlee/lowerswitch_wall_outlet.JPG
Motion sensor switch:
http://members.shaw.ca/ppwlee/motionsensor.JPG
I like to replace the lower floor light switch to a motion sensor so it will trigger the light to "on" but turn off by either the manual override on the motion sensor switch or the upper level switch (no shown).
Thanks for any suggestion.
Peter
I'm having the same problem! We have the same unit but they make a 3-way motion detector switch too. Unfortunately, I don' think Home Depot carries that model. Help!
go some where else then
