turning a Small table saw into big table saw
14 Oct 2007
Hi as you can see i am new to this site and i have just bought my 1st table saw, nothing too spectaular but should be adequate for a bit of home DIY and a few small projects.
Its a Clarke CTS10C.
This saw has quite a small 'bed' if thats the correct term. what would be the best way of increasing this bed size so that i could use the saw to cut 8x4 sheets or rip down the side of a door for example.
Many thanks
heeelllooo locoboy and welcome :D :D :D :D
some saws come with extentions as optional extras
have you got got a 20ft clear run cos thats what you need to pass a 8ft sheet over a table [9ft before 3ft table and 8ft after]
plus lots of support
best way to cut sheets is clamps strait edge and circular saw
if you do decide to make your own extention table it needs to be firmly affixed and either use the origional fence or make its own fence thats fully parralel to the blade
Yes i can have a 20ft run at it as i have a large 3 car garage:cool:
just thinking about how practical it would be to make a table with a hole in it to take the saw thus giving it a bit 'bed'
the hard bit will surely be making sure the saw bed and the extension bed are all on the same level.
Any ideas?
Any ideas?
Not if the floor is level and all legs are the same length, or build a stand for the saw with adjustable legs.
you dont want the extention covering the table
it will not only reduce the cutting depth it will stop all the tools [fence mitre guide ect] from working
the blade gaurd may also preclude this :rolleyes:
